查看: 5896|回复: 0
[核心网相关] VoLTE实战:这个INVITE请求怎么分析?
 成长值: 17515
    发表于 2017-9-11 21:35:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    目前,国内主流运营商纷纷上马volte。而volte采用了开放的sip协议作为主要通信协议,因此了解sip对掌握volte是非常重要的。
    小编特此原创整理了一篇分析文档,教新手怎么去分析一个volte的invite请求消息。希望对新手有所帮助。
    这个INVITE消息是从实际网络的pcap抓包中,替换了运营商的一些隐私信息后得到的。
    以下是该txt文档的全部内容:
    Frame 1: 1473 bytes on wire (11784 bits), 1473 bytes captured (11784 bits)
    Ethernet II, Src: 1a:04:96:a9:72:47 (1a:04:96:a9:72:47), Dst: CiscoInc_41:52:ca (00:22:56:41:52:ca)
    Internet Protocol Version 4, Src: 10.1.1.88, Dst: 200.1.1.1
    User Datagram Protocol, Src Port: 5060 (5060), Dst Port: 5080 (5080)
    Session Initiation Protocol (INVITE)
    Request-Line: INVITE tel:+8613901054321 SIP/2.0
    Method: INVITE
    Request-URI: tel:+8613901054321
    Request-URI Host Part: \n
    [Resent Packet: False]
    Message Header
    Content-Length:394
    From:<sip:+8613901012345@ims.mnc00x.mcc460.51xuetongxin.com;user=phone>;tag=e_cC73ZDU77Z3Xhb
    SIP from address: sip:+8613901012345@ims.mnc00x.mcc460.51xuetongxin.com;user=phone
    SIP from address User Part: +8613901012345
    SIP from address Host Part: ims.mnc00x.mcc460.51xuetongxin.com
    SIP From URI parameter: user=phone
    SIP from tag: e_cC73ZDU77Z3Xhb
    To:<tel:+8613901054321>
    Via:SIP/2.0/UDP 10.1.1.88:5060;branch=z9hG4bKghC676Vi82_2X39A
    Transport: UDP
    Sent-by Address: 10.1.1.88
    Sent-by port: 5060
    Branch: z9hG4bKghC676Vi82_2X39A
    Call-ID:ACD5714EAFF9E37FF90FA260@0170ffffffff
    CSeq:1 INVITE
    Sequence Number: 1
    Method: INVITE
    Max-Forwards: 70
    Route:<sip:cscf1.bj.51xuetongxin.com:5080;lr>
    Route URI: sip:cscf1.bj.51xuetongxin.com:5080;lr
    Route Host Part: cscf1.bj.51xuetongxin.com
    Route Host Port: 5080
    Route URI parameter: lr
    Record-Route:<sip:AAQAAAVJwAABwAAAAugAAfFsK@10.1.1.88:5060;lr>
    Record-Route URI: sip:AAQAAAVJwAABwAAAAugAAfFsK@10.1.1.88:5060;lr
    Record-Route Userinfo: AAQAAAVJwAABwAAAAugAAfFsK
    Record-Route Host Part: 10.1.1.88
    Record-Route Host Port: 5060
    Record-Route URI parameter: lr
    Request-Disposition:no-fork
    P-Asserted-Identity:<sip:+8613901012345@ims.mnc00x.mcc460.51xuetongxin.com;user=phone;cpc=ordinary>,<tel:+8613901012345;cpc=ordinary>
    SIP PAI Address: sip:+8613901012345@ims.mnc00x.mcc460.51xuetongxin.com;user=phone;cpc=ordinary
    SIP PAI User Part: +8613901012345
    SIP PAI Host Part: ims.mnc00x.mcc460.51xuetongxin.com
    SIP PAI URI parameter: user=phone
    SIP PAI URI parameter: cpc=ordinary
    Session-Expires:600;refresher=uac
    Min-SE:600
    Contact:sip:10.1.1.88:5060
    Contact URI: sip:10.1.1.88:5060
    Contact URI Host Part: 10.1.1.88
    Contact URI Host Port: 5060
    Require:precondition
    Supported:100rel,precondition,timer,norefersub
    Allow:ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,UPDATE
    P-Charging-Vector:icid-value=aDFHYQnMuIQnAAAAAD~MBQFwYQA-;icid-generated-at=10.1.1.88;orig-ioi=ims.mnc00x.mcc460.51xuetongxin.com
    P-Early-Media:supported
    Content-Type:application/sdp
    Content-Disposition:session;handling=required
    Message Body
    Session Description Protocol
    Session Description Protocol Version (v): 0
    Owner/Creator, Session Id (o): - 0 0 IN IP4 172.24.9.2
    Owner Username: -
    Session ID: 0
    Session Version: 0
    Owner Network Type: IN
    Owner Address Type: IP4
    Owner Address: 172.24.9.2
    Session Name (s): -
    Connection Information (c): IN IP4 172.20.11.2
    Connection Network Type: IN
    Connection Address Type: IP4
    Connection Address: 172.20.11.2
    Time Description, active time (t): 0 0
    Session Start Time: 0
    Session Stop Time: 0
    Media Description, name and address (m): audio 1226 RTP/AVP 96 97
    Media Type: audio
    Media Port: 1226
    Media Protocol: RTP/AVP
    Media Format: DynamicRTP-Type-96
    Media Format: DynamicRTP-Type-97
    Bandwidth Information (b): AS:29
    Bandwidth Modifier: AS [Application Specific (RTP session bandwidth)]
    Bandwidth Value: 29 kb/s
    Media Attribute (a): rtpmap:96 AMR/8000
    Media Attribute Fieldname: rtpmap
    Media Format: 96
    MIME Type: AMR
    Sample Rate: 8000
    Media Attribute (a): fmtp:96 mode-set=0,1,2,3,4,5,6,7; mode-change-period=2; mode-change-neighbor=1; max-red=0
    Media Attribute Fieldname: fmtp
    Media Format: 96 [AMR]
    Media format specific parameters: mode-set=0,1,2,3,4,5,6,7
    Media format specific parameters: mode-change-period=2
    Media format specific parameters: mode-change-neighbor=1
    Media format specific parameters: max-red=0
    Media Attribute (a): rtpmap:97 telephone-event/8000
    Media Format: 97
    MIME Type: telephone-event
    Sample Rate: 8000
    Media Attribute (a): ptime:20
    Media Attribute Fieldname: ptime
    Media Attribute Value: 20
    Media Attribute (a): maxptime:20
    Media Attribute Fieldname: maxptime
    Media Attribute (a): curr:qos local none
    Media Attribute Fieldname: curr
    Media Attribute Value: qos local none
    Media Attribute (a): curr:qos remote none
    Media Attribute Value: qos remote none
    Media Attribute (a): des:qos mandatory local sendrecv
    Media Attribute Fieldname: des
    Media Attribute Value: qos mandatory local sendrecv
    Media Attribute (a): des:qos none remote sendrecv
    Media Attribute Value: qos none remote sendrecv
    分析技巧及关键字段解析:
    一:SIP包头
    1)Max-Forwards: 70 :说明这是UE发给P-CSCF的,该值类似于TTL用于防止环路,初始值是70。结合Method=INVITE,知道这是一个UE发出的初始Invite消息。
    2)Request-Line tel:+8613901054321:这是用于路由的被叫号码,tel-uri格式。后续需要发给eNUM服务器翻译成SIP-URI完成IMS网络中的路由。
    3)Route:<sip:cscf1.bj.51xuetongxin.com:5080;lr>:代表INVITE消息的路由的下一跳是发给cscf1.bj.51xuetongxin.com这个节点,这是一个sip-uri,经过DNS解析后得到的应该是P-CSCF的IP地址,也就是目的IP:200.1.1.1。
    4)Via:SIP/2.0/UDP 10.1.1.88:5060。UE把自己的地址写到Via头域,Via头域决定Invite消息的响应(1xx、2xx等)如何路由。
    5)Call-ID:可以用于作为过滤条件,过滤一个完整的该用户的Dialog。
    6)Record-Route: 10.1.1.88:5060,发送方(这里是UE)将自己的地址写进去,决定了后续的SIP请求消息应如何路由。接收端给发送方发后续的SIP请求消息时,会把从接收端收到的Record-Route头域中的值复制到Route头域,并根据该地址进行路由。(所以,Via头域用于SIP响应消息的路由,Record-Route头域用于SIP请求消息的路由,这是根本的不同)。
    7)Contact:sip:10.1.1.88:5060 是UE的联系地址。用于标明直接联系请求发送方或应答方的URI地址,使以后的请求能正确路由。Contact消息头中可以包含可选参数“display-name”,用于用户界面的显示名呈现。
    8)Require和Supported头域都包含了Precondition,说明UE要求启用Precondition机制在被叫振铃前提前预留好资源(专有承载),以避免鬼振铃现象。同时隐含说明了一点,就是后续收到的第一个响应一定是带SDP的183响应而不是
    180。同时前面的Supported头域包含了100rel,代表对1xx的可靠响应支持,所以针对后面收到的183,主叫UE应该回PRACK,用于对183进行确认。
    9)Allow头域说明了UE侧所支持的SIP请求。
    二:SDP部分
    1)c line=172.20.11.2,是UE侧的RTP媒体流收发地址,现网是IPv6地址。
    2)m line=audio 1226 RTP/AVP 96 97,是UE侧所期望的编码方案,写在前面代表的96优先级更高。96和97的具体内容由下面的a line来描述。1226是端口号。
    3)b line=29,代表期望的媒体流的带宽是29 kb/s
    4)a line=rtpmap:96 AMR/8000,代表AMR编码,采样率8000。
    5)和Precondition资源预留相关的a line如下:
    - curr:qos local none
    - curr:qos remote none
    - des:qos mandatory local sendrecv
    - des:qos none remote sendrecv
    curr是当前的SDP资源预留状态,none代表没准备好。资源预留好的最终状态应该是:curr:qos local sendrecv和curr:qos remote sendrecv
    des是期望的SDP资源预留状态。资源预留好的最终状态应该是:qos mandatory local sendrecv和qos mandatory remote sendrecv。
    分析完毕,希望这部分内容对您的VoLTE学习有用哦。
    更多通信资料与视频,关注微信公众号51学通信(woyaoxuetongxin)哦。小编在那等你哦。
    GMT+8, 2025-12-14 20:28 , Processed in 0.071836 second(s), 33 queries .
