查看: 3112|回复: 0
5G NG Identities (UE and Network Identifiers)
    发表于 2018-1-21 21:42:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    UE Identifiers
    • C-RNTI:This is an unique identification, which is used as an identifier of the RRC Connection and for scheduling purposes
    • Temporary C-RNTI: This identification used for the random access procedure, Random value for contention resolution: during some transient states, the UE is temporarily identified with a random value used for contention resolution purposes
    • Multi C-RNTI:  In Dual Connectivity case, two C-RNTIs are independently allocated to the UE: one for MCG(Master Cell Group), and one for SCG (Slave Cell Group)
    • Xx-RNTI: This unique identification used to identify the UE context for RRC_INACTIVE
    Network Identifier
    The following identities are used in NG-RAN for identifying a specific network entity
    • AMF Identifier (AMF ID): It is used to identify an AMF (Access and Mobility Management Function)
    • NR Cell Global Identifier (NCGI): It is used to identify NR cells globally. The NCGI is constructed from the PLMN identity the cell belongs to and the NR Cell Identity (NCI) of the cell. It can be assumed equivalent to CGI in LTE system
    • gNB Identifier (gNB ID): It is used to identify gNBs within a PLMN. The gNB ID is contained within the NCI of its cells.
    • Global gNB ID: used to identify gNBs globally. The Global gNB ID is constructed from the PLMN identity the gNB belongs to and the gNB ID. The MCC and MNC are the same as included in the NCGI.
    • Tracking Area identity (TAI): It is used to identify tracking areas. The TAI is constructed from the PLMN identity the tracking area belongs to and the TAC (Tracking Area Code) of the Tracking Area.
    • Single Network Slice Selection Assistance information (S-NSSAI): It identifies a network slice.
    Reference: 3GPP TS 38.300 (2017-09) NR and NG-RAN Overall Description; Stage 2 (Release 15)
    GMT+8, 2025-12-16 14:49 , Processed in 0.061618 second(s), 31 queries .
