查看: 2917|回复: 0
通过iptables分析OpenStack 安全组规则
    发表于 2017-11-15 21:04:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    作者 曹云涛
    OpenStack中创建一个实例,同时会生成如下的bridgeport :
    ·tap-xxx vm用的端口,配置在libvirt配置文件中的
    ·vnet-x 图中有vnet,实际上是没有的,直接用tap插到了qbr上
    ·qbr-xxx 虚拟网桥,桥接tap和qvb
    ·qvb-xxx 连接br-int的veth端口
    ·qvo-xxx qvb-xxx的另一端
    例如:
    21:qbr14c032e9-bc: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1450 qdisc noqueuestate UP
    22: qvo14c032e9-bc@qvb14c032e9-bc:<BROADCAST,MULTICAST,PROMISC,UP,LOWER_UP> mtu 1450 qdisc pfifo_fastmaster ovs-system state UP qlen 1000
    23:qvb14c032e9-bc@qvo14c032e9-bc: <BROADCAST,MULTICAST,PROMISC,UP,LOWER_UP>mtu 1450 qdisc pfifo_fast master qbr14c032e9-bc state UP qlen 1000
    25:tap14c032e9-bc: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1450 qdiscpfifo_fast master qbr14c032e9-bc state UNKNOWN qlen 500
    查看bridge:
    $ brctl show
    bridgename bridgeid STPenabled interfaces
    qbr14c032e9-bc 8000.b21e7be143d6 no qvb14c032e9-bc tap14c032e9-bc
    分析Security Group规则
    分析FORWARD
    由于规则是配置在host的,所以进出以上端口的规则都只走forward链
    删除security group所有规则后,查看iptables
    # iptables--list -v
    Chain FORWARD (policyACCEPT 0 packets, 0 bytes)
    pkts bytes target protopt in out source destination
    348K 19Mneutron-filter-top all -- anyany anywhere anywhere
    348K 19Mneutron-openvswi-FORWARD all -- anyany anywhere anywhere
    Chainneutron-openvswi-FORWARD (1 references)
    214 25538neutron-openvswi-sg-chain all -- anyany anywhere anywhere PHYSDEV match --physdev-outtapc0a350e0-43 --physdev-is-bridged /* Direct trafficfrom the VM interface to the security group chain. */
    248 23854neutron-openvswi-sg-chain all -- anyany anywhere anywhere PHYSDEV match --physdev-in tapc0a350e0-43--physdev-is-bridged /* Direct traffic from the VM interface tothe security group chain. */
    Chainneutron-openvswi-sg-chain (4 references)
    214 25538neutron-openvswi-ic0a350e0-4all -- anyany anywhere anywhere PHYSDEV match --physdev-out tapc0a350e0-43--physdev-is-bridged /* Jump to the VM specific chain. */
    248 23854neutron-openvswi-oc0a350e0-4all -- anyany anywhere anywhere PHYSDEVmatch --physdev-in tapc0a350e0-43--physdev-is-bridged /* Jump to the VM specific chain. */
    --physdev-out tapc0a350e0-43是指tapc0a350e0-43即vm发送到bridge的包
    匹配到的包跳转到了neutron-openvswi-ic0a350e0-4
    Chainneutron-openvswi-ic0a350e0-4 (1 references)
    num pkts bytes target prot opt in out source destination
    1169 20508 RETURN all -- any any anywhere anywhere stateRELATED,ESTABLISHED /* Directpackets associated with a known session to the RETURN chain. */
    22731 RETURN udp -- any any 192.168.1.2 anywhere udpspt:bootps dpt:bootpc
    300 DROP all -- any any anywhere anywhere stateINVALID /* Drop packets that appear related to an existing connection(e.g. TCP ACK/FIN) but do not have an entry in conntrack. */
    461944 neutron-openvswi-sg-fallback all -- any any anywhere anywhere /* Send unmatched traffic tothe fallback chain. */
    Chainneutron-openvswi-sg-fallback (4 references)
    1947 71484 DROP all -- any any anywhere anywhere /* Default drop rule for unmatchedtraffic. */
    ·num:1 放行所有已建立连接的包
    ·num:2 放行192.168.1.2(dhcp服务器)发过来的udp包
    ·num:3 丢弃状态异常的tcp包
    ·num:4 丢弃不匹配以上三条的所有包
    --physdev-in tapc0a350e0-43是指从tapc0a350e0-43即vm发出来的包
    匹配到的包跳转到了neutron-openvswi-oc0a350e0-4
    Chainneutron-openvswi-oc0a350e0-4 (2 references)
    12648 RETURN udp -- any any default 255.255.255.255 udp spt:bootpc dpt:bootps /* Allow DHCP client traffic. */
    2246 23206 neutron-openvswi-sc0a350e0-4 all -- any any anywhere anywhere
    341272 RETURN udp -- any any anywhere anywhere udp spt:bootpc dpt:bootps /* Allow DHCPclient traffic. */
    400 DROP udp -- any any anywhere anywhere udp spt:bootpsdpt:bootpc /* Prevent DHCP Spoofing by VM. */
    5210 19802 RETURN all -- any any anywhere anywhere state RELATED,ESTABLISHED /* Directpackets associated with a known session to the RETURN chain. */
    600 DROP all -- any any anywhere anywhere state INVALID /* Droppackets that appear related to an existing connection (e.g. TCP ACK/FIN) but donot have an entry in conntrack. */
    700 neutron-openvswi-sg-fallback all -- any any anywhere anywhere /* Sendunmatched traffic to the fallback chain. */Chainneutron-openvswi-sc0a350e0-4 (1references)
    1246 23206 RETURN all -- any any 192.168.1.12 anywhere MAC FA:16:3E:C3:EA:D5 /* Allowtraffic from defined IP/MAC pairs. */
    200 DROP all -- any any anywhere anywhere /* Drop trafficwithout an IP/MAC allow rule. */Chain neutron-openvswi-sg-fallback (4 references)
    ·num1 允许vm发出来的dhcp udp广播包允许源端口是67,目标端口是68端口的数据包通过
    ·num2 只允许ip地址为192.168.1.12(vm的分配的ip)通过
    ·num3 允许vm(dhcp客户端)发出来的UDP 单播报文
    ·num4 禁止vm做dhcp嗅探
    ·num5 允许通过所有已建立连接的包通过
    ·num6 丢弃所以异常连接的包
    ·num7 丢弃不匹配以上任何规则包
    说明:
    obootpc 服务器向67端口(bootpc)广播dhcp回应请求
    obootps 客户端向68端口(bootps)广播dhcp请求配置
    可以看出,在不匹配security规则的情况下,除了dhcp包可以通过之外,其他数据包全部丢弃
    配置securitygroup,新增规则后再查看iptables
    增加规则1:允许vm发出的所有数据包
    查看neutron-openvswi-oc0a350e0-4链
    600 RETURN all -- any any anywhere anywhere
    700 DROP all -- any any anywhere anywhere state INVALID /* Droppackets that appear related to an existing connection (e.g. TCP ACK/FIN) but donot have an entry in conntrack. */
    800 neutron-openvswi-sg-fallback all -- any any anywhere anywhere /* Sendunmatched traffic to the fallback chain. */
    ·num6 为新增的规则,为放行所有包
    增加规则2:允许vm发出的icmp协议包通过
    查看neutron-openvswi-ic0a350e0-4链
    1169 20508 RETURN all -- any any anywhere anywhere state RELATED,ESTABLISHED /* Directpackets associated with a known session to the RETURN chain. */
    22731 RETURN udp -- any any 192.168.1.2 anywhere udp spt:bootps dpt:bootpc
    300 RETURN icmp -- any any anywhere anywhere
    400 DROP all -- any any anywhere anywhere state INVALID /* Droppackets that appear related to an existing connection (e.g. TCP ACK/FIN) but donot have an entry in conntrack. */
    561944 neutron-openvswi-sg-fallback all -- any any anywhere anywhere /* Send unmatchedtraffic to the fallback chain. */
    ·num3 为新增的规则,放行所有icmp协议包
    可以看到优化前在实时性方面原始的KVM还是会出现毛刺。在优化后基本上能达到很好的结果。
    作者介绍:
    曹云涛 ,来自诺云信息系统(上海)有限公司。
    云技术社区介绍:
    云技术社区成立于2014年,国内最大的云技术交流平台,分享在云计算/虚拟化项目实施中的资讯、经验和技术,坚持干货。
    GMT+8, 2025-12-16 07:33 , Processed in 0.063776 second(s), 32 queries .
