Eve-NG搭建的基本IPv6 lab和OSPFv3的基本配置
admin
2018-7-30 14:46
拓扑如下:
[attach]5721[/attach]
验证:
[attach]5722[/attach]
路由器上的主要配置(以R1为例,其余路由器类似):
hostname R1
ipv6 unicast-routing
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ipv6 address 2001::1111/128
ipv6 enable
ipv6 ospf 1 area 0
interface Ethernet0/0
ip address 192.168.12.1 255.255.255.0
ipv6 address 2001:12::1/64
ipv6 enable
ipv6 ospf 1 area 0
interface Ethernet0/1
ip address 192.168.13.1 255.255.255.0
ipv6 address 2001:13::1/64
ipv6 enable
ipv6 ospf 1 area 0
interface Ethernet0/2
ip address 10.1.1.11 255.255.255.0
ipv6 address 2002:AAAA::1/64
ipv6 enable
ipv6 ospf 1 area 0
ipv6 router ospf 1
router-id 1.1.1.1
复制代码
从我本机到远端R5的路由已经通了。
[attach]5723[/attach]从本机trace R5的结果:
[attach]5725[/attach]
EVE-NG统计的负荷情况:
[attach]5724[/attach]
Powered by Discuz! X3
