show databases ;
use default;
show tables ;
create table student(id int, name string) ROW FORMAT DELIMITED FIELDS TERMINATED BY '\t';
load data local inpath '/opt/datas/student.txt'into table student ;
select * from student ;
select id from student ;
# rpm -qa|grep mysql
# rpm -ivh MySQL-server-5.6.24-1.el6.x86_64.rpm
mysqld_safe --user=mysql --skip-grant-tables --skip-networking &
UPDATE user SET Password=PASSWORD('123456') where USER='root';
在cli命令行上显示当前数据库,以及查询表的行头信息
$HIVE_HOME/conf/hive-site.xml
<property>
<name>hive.cli.print.header</name>
<value>true</value>
<description>Whether to print the names of the columns in query output.</description>
</property>
<property>
<name>hive.cli.print.current.db</name>
<value>true</value>
<description>Whether to include the current database in the Hive prompt.</description>
</property>
[51xuetongxin@hadoop-senior hive-0.13.1]$ bin/hive -help
usage: hive
-d,--define <key=value> Variable subsitution to apply to hive
commands. e.g. -d A=B or --define A=B
--database <databasename> Specify the database to use
-e <quoted-query-string> SQL from command line
-f <filename> SQL from files
-H,--help Print help information
-h <hostname> connecting to Hive Server on remote host
--hiveconf <property=value> Use value for given property
--hivevar <key=value> Variable subsitution to apply to hive
commands. e.g. --hivevar A=B
-i <filename> Initialization SQL file
-p <port> connecting to Hive Server on port number
-S,--silent Silent mode in interactive shell
-v,--verbose Verbose mode (echo executed SQL to the
console)
