这篇文章是关于一个鲜为人知的让 Go 在编译期断言的方法。你可能不会使用它,但是了解一下也很有趣。 -- Josh Bleecher Snyder
编译自: http://commaok.xyz/post/compile-time-assertions
作者: Josh Bleecher Snyder
译者: geekpi
package main
import "io"
type W struct{}
func (w W) Write(b []byte) (int, error) { return len(b), nil }
func (w W) WriteString(s string) (int, error) { return len(s), nil }
type stringWriter interface {
WriteString(string) (int, error)
var _ stringWriter = W{}
func main() {
var w W
io.WriteString(w, "very long string")
main.go:14: cannot use W literal (type W) as type stringWriter in assignment:
W does not implement stringWriter (missing WriteString method)
package main
import "crypto/md5"
type Hash [16]byte
func init() {
if len(Hash{}) < md5.Size {
panic("Hash is too small")
func main() {
package main
import "C"
import "crypto/md5"
type Hash [16]byte
func hashIsTooSmall()
func init() {
hashIsTooSmall()
func main() {
$ go build .
# demo
main.hashIsTooSmall: call to external function
main.init.1: relocation target main.hashIsTooSmall not defined
main.init.1: undefined: "main.hashIsTooSmall"
