在 Go 中同时有数组(array)和切片(slice)。这可能令人困惑,但一旦你习惯了,你会喜欢上它。请相信我。 -- Jon Calhoun
本文导航
-切片 vs 数组 …… 05%
-回到测试 …… 32%
-如果 append 处理它,为什么我们还要担心容量呢? …… 64%
-不要过分优化 …… 84%
-总结 …… 86%
编译自: https://www.calhoun.io/how-to-use-slice-capacity-and-length-in-go
作者: Jon Calhoun
译者: geekpi
vals := make([]int, 5)
for i := 0; i < 5; i++ {
vals = append(vals, i)
fmt.Println(vals)
var vals [20]int
vals = i * i
subsetLen := 5
fmt.Println("The subset of our array has a length of:", subsetLen)
// Add a new item to our array
vals[subsetLen] = 123
subsetLen++
var vals []int
fmt.Println("The length of our slice is:", len(vals))
fmt.Println("The capacity of our slice is:", cap(vals))
vals = append(vals, 123)
// Accessing items is the same as an array
fmt.Println(vals[5])
fmt.Println(vals[2])
fmt.Println(vals)
fmt.Println("Capacity was:", cap(vals))
fmt.Println("Capacity is now:", cap(vals))
fmt.Println(vals)
vals = i
fmt.Println(vals)
package main
import "fmt"
func main() {
fmt.Println(keys(map[string]struct{}{
"dog": struct{}{},
"cat": struct{}{},
func keys(m map[string]struct{}) []string {
ret := make([]string, len(m))
i := 0
for key := range m {
ret = key
i++
return ret
package main
import "fmt"
func main() {
"dog": struct{}{},
"cat": struct{}{},
ret := make([]string, 0, len(m))
ret = append(ret, key)
return ret
package main
import "fmt"
func main() {
"dog": struct{}{},
"cat": struct{}{},
"mouse": struct{}{},
"wolf": struct{}{},
"alligator": struct{}{},
var ret []string
fmt.Println(cap(ret))
return ret
package main
import "fmt"
func main() {
"dog": struct{}{},
"cat": struct{}{},
"wolf": struct{}{},
return ret
你好!我写了很多关于Go、Web 开发和其他我觉得有趣的话题。
如果你想跟上最新的文章,请注册我的邮件列表[10]。我会给你发送我新书的样例、Go 的 Web 开发、以及每当有新文章(通常每周 1-2 次)会给你发送邮件。
哦,我保证不会发垃圾邮件。我像你一样讨厌它 :)
